Would you like to start using SMS to spread important announcements, updates, or a newsletter, to a large number of customers at once? Then you might consider SMS broadcasting. Read everything you need to know, in the article below.
If you prefer WhatsApp broadcasting, feel free to follow this link.
Access to SMS Broadcasting
SMS Broadcasting is available in the and needs to be activated in your account by one of our Trengo Support agents. If you wish to use Broadcasting on SMS, please reach out to team@trengo.com and ask for access.
SMS Broadcasting is available on all SMS channel types, with your own Twilio account; One-way or Two-way SMS. Do mind the requirements and limitations of SMS Broadcasting.
Requirements for SMS Broadcasting
You need the following to use SMS broadcasting in Trengo.
πŸ”˜ An active SMS channel.
πŸ”˜ A subscription to the Trengo Boost or Pro plan.
πŸ”˜ Approval from our Support agents to use SMS Broadcasting.
πŸ”˜ If you have connected your number directly via Trengo, you need enough third party carrier cost your account. In case you have connected number with your own Twilio account, make sure you have sufficient Twilio balance.
Limitations of SMS broadcasting
Keep the following in mind when using SMS broadcasting in Trengo.
πŸ”˜ SMS messages have a limit of 160 characters. It is possible to exceed the number of characters, but the message will automatically be split up into multiple messages which will result in extra costs.
πŸ”˜ There will be a delay in sending, which is reflected in the status β€˜sending’. The delay makes sure that your Trengo inbox is not overloaded with requests.
πŸ”˜ The Broadcasting overview gives an estimated amount of costs, not the exact costs. This is due to discounts, and also the length of the actual SMS message.
πŸ”˜ Tags may influence the length of a message once it has been actually sent. Therefore the costs of an SMS will always be an estimation when using tags.
Good to know
SMS broadcasting is disabled by default for all agencies, even if you already have purchased the . Trengo will only allow SMS Broadcasting to valid organisations to prevent spam or fraudulent use of this feature.
To gain access to SMS broadcasting, reach out to our support team via team@trengo.com with an email address that is linked to your Trengo account. Make sure to mention your company name and the reason you wish to use SMS Broadcasting. After research by our team, we will either accept or reject your request, or ask for additional information.
If you’re ready to send a broadcast message, want to check out WhatsApp broadcasting, or like to read more about broadcasting, follow the links provided.
