By integrating Booking Experts and Trengo, businesses will be able to have more enriched conversations with guests by including reservation information from Booking Experts directly in Trengo’s platform. This integration will combine your customers' favourite channels, customer profiles, and booking details in one place for fast access.
Highlighted features and benefits
  • 🔁 Centralise guest communication: Sync conversations from Booking Experts into Trengo (and vice versa) to easily access messages from your guests in both platforms, across all channels.
  • ⏰ Access booking details directly in conversations and save time: Agents can view booking information from Booking Experts (like stay dates, guest data, and booking status) without leaving Trengo, speeding up support.
  • ⚡️ Automate and streamline workflows: Use Trengo Journeys to send automated messages, confirmations or FAQs based on Booking Experts data and triggers, reducing manual work and response times.
Connect Booking Experts and Trengo
To start using the Booking Experts integration, follow these steps:
  1. Ensure you are an Administrator in Trengo & Booking Experts.
  2. In the Trengo app, navigate to Settings → Integrations → Booking Experts.
  3. Click the “Install Integration” button located at the top right of the screen.
  1. This will take you to BookingExperts app store where you need to log into your account. In case you are not yet logged in to Booking Experts, please log in.
  1. Next click on Install and you will be redirected to the ‘permissions’ page.
  1. After allowing permissions and clicking install you will be redirected to Trengo and the integration has been added.
How to Use the Integration
Once installed, guest and reservation details from Booking Experts appear automatically in Trengo, no need to search for anything manually.
Where to find it
Open any conversation with a guest and check the Integrations tab in the right-hand sidebar. Trengo matches the contact to their Booking Experts profile using their email, phone number, or booking reference, and shows:
  • Guest details: name, contact info, nationality, language, and address
  • Reservations, split into three tabs — Current, Upcoming, and Past
  • Per reservation: check-in/check-out dates, room or unit, booking source and channel, rate/price, and (for Booking Experts specifically) amenities and booked extras
This works across every channel connected to Trengo - email, WhatsApp, and OTA channels like Booking.com - as long as the guest's contact details match a synced reservation.
Jumping into Booking Experts
Every reservation card includes a direct link through to that reservation in Booking Experts, so agents can open it there for anything that needs to be changed.
The sync is one-way: Trengo pulls reservation and guest data in from Booking Experts, but nothing is pushed back. Any edits still need to happen in Booking Experts itself.
Automating guest communication
Beyond the sidebar, the integration also powers Trengo Journeys. You can trigger automated WhatsApp messages - pre-arrival info, check-in reminders, post-stay follow-ups - on:
  • Reservation confirmed
  • Reservation checked in
  • Reservation checked out
  • Reservation cancelled
Synchronising data between Trengo and Booking Experts
When connecting your Trengo account with Booking Experts, data from both platforms will be synchronised for up to 6 months in the past. This means that under the "Past Reservations" section, you will only see reservations from the last 6 months.
The initial synchronisation process can take 3 to 5 hours to complete. After the initial setup, updates will be synchronised in real time.
Please take this potential delay into account before going live with the integration.
Common Questions
Why can’t I find a guest’s reservation in the sidebar?
Trengo only shows reservations it has synced. This covers changes from roughly 6 months before you installed the integration onward. Also check that the email or phone number on the Trengo contact matches the Booking Experts reservation exactly.
Can I edit a reservation from Trengo?
No, the sidebar is read-only. Use the link on the reservation card to open and edit it in Booking Experts.
Does the integration show property owners, cleaners, or managers?
Not currently. It only syncs reservations and the guest tied to each one. Owners, cleaners, and managers are a separate relationship type in Booking Experts and aren’t retrieved.
Is Booking Experts included in my Trengo plan?
It’s a Basic integration, available on plans with integration access. If Hospitality integrations aren’t visible under Settings → Apps & Integrations, check with your account manager.
Can I run this alongside a custom-built Booking Experts integration?
Yes, the standard Trengo integration can run in parallel with a custom-built one on the same account.
Why isn’t my Journey triggering when a reservation is confirmed?
Make sure the integration is switched on under Settings → Integrations. Journeys only fire on a genuine status change into “confirmed” — an already-confirmed reservation that’s just edited won’t retrigger it, and reservations last modified before you installed the integration are skipped.
