By integrating Klaviyo with Trengo, you can automate processes in Trengo, based on triggers in Klaviyo. In this series of articles, we’ll show you how to have your customers opt-in (and opt-out) for e.g. your WhatsApp newsletter in Klaviyo.
After you’ve enabled your number in Klaviyo, it’s time for a rule that communicates the opt-in to Klaviyo. Below you'll find a video explaining how to set up the rule for opt-in in Trengo (from 01:59).
Setting up a rule for opt-in in Trengo
Follow the steps below to set up a rule for opt-in in Trengo. You can also use the steps below to set up your opt-out.
1. Make sure you already have an approved WhatsApp template, in which you ask your customer if they’d like to opt-in. Enable your customer to answer using buttons, or the rule you’re going to set up next will not work consistently;
![](https://cdn.prod.website-files.com/65361e47b48ed882c2549852/65361e47b48ed882c254aa71_Rule_K_Step%201.webp)
2. In Trengo, navigate to Settings > Automation > Rules, and click the ‘plus’ icon, or ‘Add rule’;
![](https://cdn.prod.website-files.com/65361e47b48ed882c2549852/65361e47b48ed882c254aa72_Rule_K_Step%202.webp)
3. Set up the rule as follows;
![](https://cdn.prod.website-files.com/65361e47b48ed882c2549852/65361e47b48ed882c254aa73_Rule_K_Step%203a.webp)
1. Name: Enter a suitable name for this rule.
2. Active: Leave this toggle enabled.
3. Channels: Select the WhatsApp Business channel on which the template you’ve created is active.
4. When: Set this to ‘Inbound message is received’.
ℹ️ You can leave ‘Sort order’ empty.
![](https://cdn.prod.website-files.com/65361e47b48ed882c2549852/65361e47b48ed882c254aa74_Rule_K_Step%203b.webp)
1. Conditions: Set Message body > Equals to the text of the button you’re customer would use when agreeing to receive your messages. In this case, it would be ‘Yes, I would!’, according to the template given as an example above.
2. Actions: Choose ‘Send Opt-in to Klaviyo’ and enter your site ID.
ℹ️ This site ID can be found by navigating to Klaviyo > Account > Settings > API Keys, under ‘Public API Key’.
After clicking ‘Save’, you’ve now successfully created a rule that lets customers opt-in (or opt-out) to e.g. your WhatsApp newsletter. Finally, it’s now time to check in on the customers in Klaviyo that have opted-in for your automated messages.
